Car starts but won't run with Turner/TMS chip
  • grib
    • Oct 2006
    • 151
    Unfortunately I am having a problem with a chip I bought from Turner Motorsports. The car starts with the chip in, but then barely runs and dies after only 10 seconds. I can keep it from dying by keeping the throttle at 1500-2000 RPMS - but it will die immediately after if I let off the throttle. This doesn't appear to take long enough to trigger the CEL, so there isn't a fault code from the ECU.
    The "stock" chip starts and runs decently, but the CEL will come on after 5 minutes or so (probably due to the injectors being unmapped, but I have not read the code).
    S52 w/OBD-1 conversion
    Red label 413 ECU (tried two different units)
    THR wiring harness
    24 lb injectors
    UUC flywheel
    Tried both 3" and 3.5" MAF
    Tried two different TPS
    I also tried with combinations of the TPS and MAF unplugged but it ran even worse that way. Most of the sensors on the car (knock, crank/cam position). The ignition coils are new as well.
    I sent the chip back to TMS, and they returned it saying that they tested it and did not find a problem.
    Has anyone else ever had this problem?
    1987 325i Cabrio - SOLD
    2014 Chevy Volt
    2007 FJ Cruiser
  • matt
    • 3732
    How is your ICV?
    • grib
      • Oct 2006
      • 151
      Have not tested it. It's used, but I cleaned it prior to installing. It does hum quite loudly when the key is turned to on.
      Is there a procedure to test?
      2014 Chevy Volt
      2007 FJ Cruiser
      • erik325i
        • Jan 2005
        • 3567
        I have the Peake Research code checker tool if you want to borrow it. I'll bring it to the meet on Sunday.
        -Erik
        • matt
          • 3732
          You may have another running issue with the motor that isn't chip related.
          It really sounds like a MAF issue. Could be ICV also.
          • BeirBrennerE30
            • 2740
            ICV or a major vac leak...
            my biggest probelm on my first 2 swaps were vac leak related and the car would start idle rough and sputter out but on throttle be better. sounds like what you have
            e30sport.net
            '06 M3 Competition - 6-speed
            '97 Range Rover Vitesse
            • Beej '86 325es
              • 2639
              The bentley has a relatively simple way to test the ICV, that just takes a 12V power source and a couple of wires.
              -Brandon
              '86 325es S50
              '12 VW GTI Autobahn DSG
              '03 540i M-Sport (sold)
              '08 Jeep SRT-8 (sold)
              For sale:
              S50 TMS chip for Schricks
              • grib
                • Oct 2006
                • 151
                -Erik
                Thanks Erik, I'll take you up on that.
                Matt, I have ordered a new MAF to see if that's it. It's something I wanted to get anyway. I am also going to replace the O2 sensor this weekend.
                2014 Chevy Volt
                2007 FJ Cruiser
                • matt
                  • 3732
                  It's not the O2 sensor.
                  • 1990m3
                    • 1180
                    vacuum leak sounds likely. There aren't too many vacuum hoses on these engines, check your connections again!
                    • RyanZ06
                      • Apr 2007
                      • 226
                      I dont think it's a vacuum leak. I am having a similar problem, I have SEALED all vacuum ports except for those vital few (FPR, brake booster). My car has identical symptoms.
                      • trent
                        Are you sure you guys didn't miss the vacuum port on the TB?
                        • grib
                          • Oct 2006
                          • 151
                          I capped off the two coolant ports, but there is one left. This is probably the vacuum port. Is this supposed to connect to the purge valve?
                          2014 Chevy Volt
                          2007 FJ Cruiser
                          • trent
                            Yes, that is a vacuum port. I don't know if this to your problem but it certainly is an issue. It is supposed to goto the purge valve.
                            • BeirBrennerE30
                              • 2740
                              on obd1 engines there is another vac port on the icv pipe that like everyone forgets. Also the throttke body purge port that trent mentioned... jb weld is your friend
                              e30sport.net
