Sensors for obd2 to obd1 conversion
  • svn2002s
    • Sep 2004
    • 478
    When ordering the following sensors everything should be for a 95 m3 right?
    Crank Position Sensor
    Cam Position Sensor
    Ping/Knock Sensor
    Oxygen Sensor
    Just need to make sure I order the right stuff.
  • matt
    • 3731
    The O2 sensor can be from almost anything... but not the OBD2 ones. Hell, the e30 one works fine.
    You'll also need the wire to extend the Vanos solenoid lead if you're still using the OBDII vanos solenoid. The part number is in the wiki.
    • svn2002s
      • Sep 2004
      • 478
      Thanks, I'll follow up with a PM later this week. Chip & DME (Do I need bigger injectors?)
      • matt
        • 3731
        You probably don't, unless your setup is way not-stock. PM me your motor and mod info and I can do the math to be sure.
        I have chips, injectors, and DMEs if you do need something.
        • grib
          • Oct 2006
          • 151
          Don't forget that you'll need two knock sensors (same PN, qty 2) for the OBD1 setup. They are separate (and sold separately), unlike the OBD2 which is two sensors on one pigtail.
          1987 325i Cabrio - SOLD
          2014 Chevy Volt
          2007 FJ Cruiser
