e30 m52 s14 s50 weight comparisons
  • Jason89i
    • Sep 2004
    • 875
    ive always wondered. how bad are they? i could feel the weight on my e30s52m3, but ive never really known.
    we borrowed some corner scales, and, well, we just couldnt resist. weight comparison
    88e30m3, euro s50b32, no a/c, no driver.
    full tank of gas, no weight reduction, stock seats, full interior.
    2846# 54.3%f 45.7%r
    91e30 318is, aluminum m52 2.8, no ac, no driver.
    full tank of gas, no weight reduction, vader seats, full interior.
    2684# 53.4%f 46.7%r
    90e30 325i, s50, no ac, no driver.
    full tank of gas, no weight reduction ((still has trunk sound deadening), light floor mount seats, full interior.
    2844# 52.3%f 47.3%r
    88e30m3 s14, no ac, no driver.
    full tank of gas, a/n cf, floor mount fixed back seats, no rear seats, roll bar.
    2810# 51.2%f 48.8%r
    i found it suprizing how different the cars "feel" vs. what the scales said. so, how much does a cf hood weigh?
    cheers, jason
  • Teaguer
    • Sep 2004
    • 6167
    Great thread Jason , this is really good info to have .
    Im guessing since your M3's are 88's that they are running the steel control arms ?
    Also the 325i is a 2-door or 4-door ?
    I believe the MaShaw hoods weigh like 10-12lbs and bolt up to the hinges .
    • Jason89i
      • Sep 2004
      • 875
      Also the 325i is a 2-door or 4-door ?.
      good call. my m3 (euro s50) has alum control arms, not sure about the s14'd m3. new guy.....want to chime in?
      all cars were 2 doors.
      cheers, jason
      • asubimmer
        • 6482
        great thread
        • Mike B.
          • Jan 2006
          • 987
          I can get you a FRP race weight hood that weighs around 7lbs, but you'll need hood pins. One that uses the stock mounts will weigh around 12-15lbs.
          I'll weigh my 318is (S50B32 / steel control arms / coilovers / no AC) on my corner balance scales and report back.
          • asubimmer
            • 6482
            price for the hood?
            • PiercedE30
              • Apr 2005
              • 4220
              It's funny that the 318 with the aluminum block is close to 200 pounds lighter than the rest.
              My 2.9L Build!
              • madjurgen
                • May 2005
                • 1203
                The scales say you have an additional 107lbs on your front axle compared to a s14 e30m3. Thats probably what youre feeling.
                As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                • AdamF 88iS
                  • 2051
                  Except that 318s have iron blocks.
                  Adam Fogg- '88 M3
                  Common sense- It's the new 'gifted'
                  • asubimmer
                    • 6482
                    "91e30 318is, aluminum m52 2.8"
                    we aren't talking about the m42 here
                    • Jason89i
                      • Sep 2004
                      • 875
                      there's no doubt about it. i could feel a difference on turnin by removing the a/c comp. 20# cantilevered over the front axil. yes, it does make a difference if you track a car.
                      now i really want to weigh my stock m42 318is....it "feels" better / lighter than my s14'd m3. i would bet its lighter in the nose than an s14 m3 by at least 40#. anyone with some data???
                      160# to the heaviest pig in the lot...(my car.)
                      cheers, jason
                      • FredK
                        • 14761
                        Ya, and it even has VADERs, which are more dense than depleted uranium. I think a 318is weighs right around 2600 stock.
                        • static
                          • Oct 2005
                          • 501
                          http://www.bimmerforums.com/engine_faq/
                          m42 is 34lb lighter than s14
                          US m50/s50 is around 300lb and alu blocked is 260lb
                          one more thing you guys have to keep in mind is that straight6 stick out past the front axel, which is detrimental for handling.
                          I am kind of tired of my s50e30's heavy nose understeer at autox's and track, so i've been toying with idea of a turbo'ed M42 instead.
                          • Jason89i
                            • Sep 2004
                            • 875
                            Originally posted by static
                            ......... understeer at autox's and track, so i've been toying with idea of a turbo'ed M42 instead.
                            understeer? never had a problem. you just need an adjustable rear bar.
                            turbo m42? (disclaimer: now i know nothing about turbo cars) i know you can super charge them, but a turbo w/o knock sensors sounds dangerous. my m42 just developed some noise. not sure what to do. i do want to keep the m42..... but.... the power is sooooo addictive. can the m42 actually get some torque? i would be VERY interested.
                            cheers, jason
                            • AdamF 88iS
                              • 2051
                              Eh. Brain fart.
                              Adam Fogg- '88 M3
