M50 swap Drive line
  • Nj85'325
    • Dec 2006
    • 90
    M50 swap Drive line
    Im looking for peoples input on driveline parts.
    Im using a Getrag 260 in an M50 swap.
    Which flywheel do you use?
    Which Clutch kit do you use?
    Which of both would you want most if you had the money for it?
    Thank you for your help
  • cahomey
    • Mar 2004
    • 1201
    shaved m20 flywheel
    stock m20 clutch
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
    • gazellebeigem3
      • Jun 2005
      • 3712
      or e36 flyweel/clutch/starter
      • Nj85'325
        • Dec 2006
        • 90
        Anyone running an alumn. flywheel? and does anyone know what the stock clutch is rated for, HP/TQ?
        • PiercedE30
          • Apr 2005
          • 4220
          I have a JB Racing 8.5 lb flywheel. Still need to decide on a clutch.
          edit: I think the stock clutch/pp is rated for like 240 or so.
          My 2.9L Build!
          • Mr.SWISS
            • Nov 2005
            • 1251
            Just to keep it as simple as possible I used the e36 325i trans with all e36 stuff. (starter, M3 Sachs Performance clutch, M3 Fidanza lightweight flywheel)
            Originally posted by 325Projectz
            don't listen to the diagram... listen to mr. swiss.
            :nice:
            • 325Projectz
              • Jan 2005
              • 1956
              ha, nice sig!
              91 m3
              • matt
                • 3732
                The stock e30 clutch will slip at 320ftlbs. I had a quote about this in GRM a few months ago.
                High torque cars will eat e30 clutches. Get a stock e36 M3 clutch and use that instead if you're planning anything big.
                • BigD
                  • Jul 2006
                  • 1085
                  Or the UUC Stage 2 + M5 clutch (what I'm using, I actually have a reinforced pressure plate + kevlar clutch)
                  • Nj85'325
                    • Dec 2006
                    • 90
                    the m5 will work with getrag?
