called turner for a chip they said nothing for me
  • ericzz
    • 286
    s52
    pink tops
    540 3.5hfm
    413 red label dme
    am I doing something wrong ?
  • FredK
    • 14761
    Turner only has chips for 24# injectors, 3.5 HFM, S50. I believe Stickley (www.cssmotorsports.com) at one point did 21.5 injectors. I am not sure he still sells software. Active (www.aatuning.com) I think has a chip for that combo.
    • ericzz
      • 286
      Would you just buy the injectors and the chip from turner ? is it worth the $ for the upgrade ? is there a cheaper source for the injectors ? or a bosh part # I can get them from a local upplier I have an account with ? I would need an application to do so . Does anyone have an OEM application for these ?
      • Van Westervelt
        • 9365
        I have a set of new 24 lb boschs from turner, 225 shipped for you.
        • static
          • Oct 2005
          • 501
          contact MarkD, he will make a chip for you. He has one for 24#, but changing tune for 21.5# is a piece of cake
          • 325Projectz
            • Jan 2005
            • 1956
            i called turner about that too. when i upgrade from a s50 to a s52, they said just run the same chip. (which i plan on)
            i'm sure a custom tune would be ultimate, $$$.
            91 m3
            • matt
              • 3731
              Boo active chips. :down:
              We should have a chip for this setup in the next few weeks. Need to find some time to hit the dyno with a box of injectors and MAFs and an S52. :up:
              • BDSax
                Junkyard King
                • Mar 2006
                • 3594
                ^ Matt FTW.
                When you comimg to florida and helping with my m50 swap!
                • matt
                  • 3731
                  Originally posted by BDSax
                  ^ Matt FTW.
                  Heh, I wish. You talk to Ben? (///Mpressive)
                  • MarkD
                    • Sep 2004
                    • 488
                    Originally posted by ericzz
                    s52
                    pink tops
                    540 3.5hfm
                    413 red label dme
                    I made a chip for that setup a few weeks ago for a track car.
                    URL: www.dsylva-tech.ca
                    • C ///M
                      • 1040
                      Hey Mark, I've tried emailing you a couple times in the past. I know you're a fairly busy individual.
                      Do you have any options for an E36 506 DME?
                      I currently run a pre 1/95 E36 M3 506 DME on my:
                      OBDI s52
                      euro 3.5" hfm
                      24# injectors
                      Do you have anything for me? I still run Turner's 3.0 liter software for the above application.
                      332iS R.I.P.
                      • MarkD
                        • Sep 2004
                        • 488
                        OBDI s52
                        euro 3.5" hfm
                        24# injectors
                        I Chris,
                        I just sent you an email. I have something that should work but I don't know how it compares to what you have maybe your current chip is better.
                        I see you are in Chicago, I was there for a week in June.
                        Mark
                        • C ///M
                          • 1040
                          I Chris,
                          Mark
                          Thanks Mark, sent you a reply.
                          332iS R.I.P.
