E34 525i Booster Same As Ix
  • ericzz
    • 286
    I bought a 525i for obd1 donor and pan etc . noticed the booster looked kind of small and I check the part # same as IX . So it looks like an obd 1 525 is a great donor car , harness,pan and brakes .
  • 325Projectz
    • Jan 2005
    • 1956
    slap hands!
    91 m3
    • Rigmaster
      • 3464
      What's the BMW part number?
      I checked realoem.com and the E34 uses 2 different boosters, 1 ATE and 1 Girling. Neither of them come up as being the same as the 325ix booster though....
      Bret.
      • PiercedE30
        • Apr 2005
        • 4220
        the 535i booster is the same though.
        My 2.9L Build!
        • ericzz
          • 286
          WWW.ROCKAUTO.COM same part # . I compared the two side by side and measured them they are exact !
          • matt
            • 3732
            You will need a piece to connect the booster to the firewall, I think.
            • ericzz
              • 286
              It appears to have the same adapter on it 2 into 4 unsure if the pattern is exact but it does has an adapter preinstalled
              • streetknight
                • Oct 2005
                • 236
                2 question does the 525 e34 have to have the m50 engine? and where is the part # on it?
                • ericzz
                  • 286
                  Yes same m50 . I am using a bunch more e34 iems I will post pictures in a few weeks .
                  • ericzz
                    • 286
                    The resevoir happens to me a triangle shape and seems top be further off set to the left . The master is the same length itself . With the offset I think it will be a winning setup . I should have the driveline bloted in by the weekend .
