Engine wiring harness question...
  • bwh13
    • Jan 2007
    • 437
    I have an S52 doing the OBD1 conversion using the engine harness from a 95 525i, this is going into my E30.
    I am putting on the harness and can't figure out which connectors go to which sensors. Is there a chart giving that info somewhere? There must be 4 or 5 two pin connectors on this harness as well as a couple of 3 pin connectors that I can't figure out what they are sipposed to connect to...none of the connectors have any identifying marks as to which sensor to connect to.
  • Mike B.
    • Jan 2006
    • 987
    Pull back the covers to determine the wire colors, then go to the back of the Bentley and start matching.
    • gazellebeigem3
      • Jun 2005
      • 3712
      I had to do it too. If you dont have a bentley, heres the list:
      • bwh13
        • Jan 2007
        • 437
        Thanks guys that's just what I needed...
        • bwh13
          • Jan 2007
          • 437
          OK I ran into a snag...the crank sensor has a 3 wire plug, but the list of harness wires and their colors says it has 1 yellow wire, but it has 3 wires; yellow, clear and another color which I can't remember right now...do I still hook it up, even though it has 3 wires not just 1? Sounds kind of silly but I want to make sure it's OK.
