e30 with m54b30
  • Jean
    • 18228
    e30 with m54b30
    Link - http://www.e30tech.com/forum/viewtop...er=asc&start=0
    There is video there too, check it out. :up:
  • matt
    • 3731
    I wish to subscribe to that guys newsletter.
    • Teaguer
      • Sep 2004
      • 6167
      Nice soldering skills inside the DME .
      But if its running who cares , right ? :D
      And whats the deal with the crap intakes on those engines , is it possoble and are there gains to be had to switching to like a OBDI M50 manifold ?
      • matt
        • 3731
        It's an excellent intake manifold.
        • alexbaby88
          • 219
          if the economics work for you, a stroker using the S52/M54 crank, 135mm conrods and M54 pistons will take your 2.5L M50 to 3.0L with unchanged 84mm bore and stroke lengthened to 89.6mm.
          So basically an iron block M50B30.
          • Jean
            • 18228
            Is s52 crank = m54 crank ?
            • alexbaby88
              • 219
              yes
              11 210 007 260
              • Jean
                • 18228
                Originally posted by alexbaby88
                yes
                11 210 007 260
                I am sorry if this has been covered before, what are the 135mm rods from ? Will the 260 crank fit any m5x block (including z3 block) ?
                • alexbaby88
                  • 219
                  IIRC S50, S52, M52B28 and M54B30 rods are all 135mm.
                  I believe the S52/M54 crank fits M50B25 and M52B28 (mainly iron blocked in USA, but alloy blocked for the Euros) blocks.
                  • So Live
                    • 2512
                    what kindov hp would we be looking at with the m54 rotating assembly but with all the m50 b/s? anyone know?
                    -Chris
                    • Teaguer
                      • Sep 2004
                      • 6167
                      You would effectively have an S50 at that point minus the cams .
                      But most would install S50 (or better) cams anyway .
                      • Jean
                        • 18228
                        Thanks!
                        Does anybody know if there is a reason why it wouldn't fit aluminum z3 block ?
                        • kylebes1
                          • May 2004
                          • 2804
                          It will fit the alloy block
                          • matt
                            • 3731
                            Not really, it would be a 3.0l stroker.
                            Longer stroke and narrower bore than a real S50.
                            • SpecM
                              • Oct 2005
                              • 4531
                              -So... better or worse than an s50?
                              1989 cirrisblau-metallic 325i
