Ok I searched . I have all the stuff everyone else is using m5 mounts e36 arm and radiator . I tried a 525 fan/clutch no fit I tried my old e30 m3 clutch and fan no fit . Is there a specific fan package that fits or should I just go electric and be done with it .
what fan/clutch are you using
electric, why would you use something else?!?
I had about 1/4" room btw my 318is rad and the 94'325i fan clutch but screw that///Alpinweiß II 24v 91' 318is, Alpinweiß III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
I dont use a fan, got the 80 Deg thermostat and the 88 Deg aux fan switch, and my car rarely gets to the center in my coolant temp gauge. Also after I upgraded to an all-aluminum bigger radiator, it hardly ever even moves at all.
You can fit a fan if you really want to, but it has to be on before the radiator is put in the car.Perot isn't a Hillary hater, but he's not a fan either, relating the bumper sticker he received that reads: "Monica Lewinsky's Ex-Boyfriend's Wife for President."Comment
electric FTWMy 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
i'm using a stock m20 clutch and fan. The scret is to turn the fanthe other way round for fitment, you will need to experiment a few times to get it right
the other way is to get a super slim 324td clutch fan, which will fit with ease and only setback i found is that the radiator has got to be removed if the fan clutch needs to be changedComment
both i want to get rid of both of them in the long run. just have 1 fan as a push from up front.Comment
