Which front strut bars fit with our motors?
  • matt
    • 3731
    Is there any clearance issue with the Sparco? IE? Mason/Vorshlag?
    Thanks!
  • Brew
    • 3060
    Sparco works.
    '91 318is
    • BeirBrennerE30
      • 2740
      Originally posted by Brew
      Sparco works.
      indeed...
      e30sport.net
      '06 M3 Competition - 6-speed
      '97 Range Rover Vitesse
      • grib
        • Oct 2006
        • 151
        Sparco works.
        It clears, but won't fit over the wiring cover that sits on top of the intake manifold/coil cover - so you would have to ditch that piece.
        1987 325i Cabrio - SOLD
        2014 Chevy Volt
        2007 FJ Cruiser
        • SchnellerVert
          • Sep 2005
          • 3948
          Yes it does.
          • 1990m3
            • 1180
            racing dynamics works too
            • Brew
              • 3060
              What cover? I'm using the M42/S14 harness cover and it fits fine.
              '91 318is
              • SpecM
                • Oct 2005
                • 4531
                -I think he means the valve cover plastic trim
                1989 cirrisblau-metallic 325i
                • SchnellerVert
                  • Sep 2005
                  • 3948
                  Fits fine over the plastic valve cover in buddies car. What mounts did you use?
                  • LINUS
                    • 2422
                    Let me guess.....you still have the E36 harness cover on & laid over the valve cover. Get the E30 M3 piece, and then crack that old thing open, rip out unneeded wires, rewrap & put in M3 cover. Now any bar will fit.
                    Sorry if I'm wrong, but that's like the only possible way I can see that a bar won't fit.
                    It's not how you handle the good times, but the faith you keep in the bad that defines you.
                    • rede30
                      • 4697
                      My eibach bar fits fine. There will be no camber plates with it but for now its fine.
                      • grib
                        • Oct 2006
                        • 151
                        Bingo, the E36 wiring harness cover. The Sparco won't fit over that. I intend to clean the cover up a bit (thanks for the tip on the E30 M3 cover) but it's not at the top of the list for th moment.
                        FWIW it's in a cabrio - not sure that makes a difference.
                        2014 Chevy Volt
                        2007 FJ Cruiser
                        • matt
                          • 3731
                          Thanks guys.
                          No word on the Vorshlag/Mason bar? That's the one I'm eyeing at the moment.
                          • BeirBrennerE30
                            • 2740
                            Originally posted by matt
                            Thanks guys.
                            vlad rocks it on his s52 i think... looks like it fits to me
                            e30sport.net
                            • Skafrog
                              • 1732
                              Hell, the sparco bar fits here in TN with the stock E36 Cover.
                              NASA MidSouth TT Director / GTS2 #018
                              Mods: Coastal PS Fluid, 10w40 Oil
                              Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
