e34 harness oil level sensor ?
    Treehouse adapter is being used , Should it have been wired allready correctly or do I need to make a change at the sensor ? I prefer to have it working .
    My THR harness has plainly tagged pigtails to hook it up, - yours doesn't?
    I have 3-4 wires, a couple for the OLS, then IIRC a hot lead for the ABS trigger.
    It's not how you handle the good times, but the faith you keep in the bad that defines you.
      No just an ABs trigger red wire . I guess I better make a call to THR!
