I am having trouble with my ZF clutch master cylinder. How to you bleed these suckers? the pedal is very soft and i pop out of gear a lot. I have been puping away and nothign flows threw the unit. Any tricks you guys know? I also closed the valve and had a friend pump a lot and no real pressure built up. Do i just do this a ton?
Tags: None
You have a bleed screw on it just like your brake calipers. Need more info (recent swap, new slave cylinder, physically is your hydraulic line in good shape, etc.), otherwise we are all guessing.
It's not how you handle the good times, but the faith you keep in the bad that defines you. -
I have been treating it just like a caliper and yes i have been using the bleed screw. My line is brand new, the slave is old but it worked before this swap. The car sat for about a year and a half and has about 10 miles on the s50 swap. The clutch seems to grab really well so there is no slipping.Comment
I pulled mine off the transmission and pushed the rod in all the way then opened the bleeder screw fluid/air comes out. Closed bleeder screw before releasing rod. Repeat untill no air comes out.
Are you pulling the fluid through under vacuum, or pushing from the brake cylinder when bleeding? - May not solve anything, just wondering really. I'm bleeding my whole system tomorrow as a fresh buildup (dry right now), sort of wondering what I'm in for now too.
I've got it pretty easy since I just have one of those deals you hook up to compressed air and it pulls fluid under vacuum. Love that thing. Makes oil changes a dream just shoving that rod down the dipstick tube.
It's not how you handle the good times, but the faith you keep in the bad that defines you.Comment
I used a vacuum bleeder on mine with a helper pumping the clutch. It still took at least 10 cycles of pumping/bleeding before the clutch felt solid, and I'm still not sure it's 100%.
Be certain while you're bleeding that the clutch intake (blue/braided line going into the reservoir) has fluid to draw from or you're just sucking in air. The reservoir will need to be above full and the car tipped forward to best results.
It's a PITA to lay under the car and bleed that thing, but keep at it.
1987 325i Cabrio - SOLD
2014 Chevy Volt
2007 FJ CruiserComment
