Anyone run a T block from the oil pressure port...
  • bwh13
    • Jan 2007
    • 437
    I will be putting a pressure guage on the S52 and want to run it off the oil pressure sending unit port on the oil pump. Is there any T block that works better than others or should I machine my own?
  • matt
    • 3732
    I can help you with that: http://www.racersmarket.net/catalog/...products_id=43
    Matt
    • ericzz
      • 286
      could I run my e30 m3 oil temp switch on this ? does it go in the oil pressure switch hole ?'
      • matt
        • 3732
        Possibly, but the threads on the adapter won't fit,you'd have to drill out the hole and re-tap it.
        • BigD
          • Jul 2006
          • 1085
          I got one of these (my item expired, msg the seller, he always has more):
          http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=300128608757
          Nicely made, he can make it with whatever threads you want and it lets you add 2 sensors as I wanted - oil pressure and temp.
          • bwh13
            • Jan 2007
            • 437
            Thanks Matt, just what I needed. The other piece on Ebay I can make myself for a lot less...
