3.46:1 ya or na
  • matt
    • 3731
    #31
    You guys having speedo and tach issues... just send your clusters to a speedo shop. They can calibrate them properly for any faceplate.
    • Mike B.
      • Jan 2006
      • 987
      #32
      Originally posted by ericzz
      Read this quote , this is what I have done
      Small problem...
      Since the car comes with a 8k tach and 4 cyl coding plug, it isn't going to read right (but you already know this).
      So you need a 6 cyl coding plug, but problem is, bmw never made a 6 cyl coding plug for a 8k tach. If you put the 7k 6 cyl coding plug (325i) in it, at redline, which is 8k, the engine will really be at ~7k. You can switch the gauge face back to a 7k tach (thats no fun though) and it will be spot on.
      My guess is that it is possible to retain the 8k redline, but would probably cost a pretty penny or two. If someelse knows more, chime in!
      Since we're jacking this thread...
      You need something like this to get the correct tach output with the 8k tach - http://www.dakotadigital.com/index.c...cat/cat287.htm
      Or do what Matt suggests and contact North Hollywood Speedo or Palo Alto Speedo to have it adjusted to read correctly.
      • tjhartge
        • Jun 2004
        • 86
        #33
        *****OT******
        or get in touch with Rev Engineer, he has a cool tach converter, you can use if you have an M3 cluster with m/s50 engine
        he is also coming up with an OBC converter to read MPG accurately
        back to topic
        I think 3.46 daily drive with 30-40% highways would be ok, and yes, it does leave a smile on my face when i pull away faster then the newer e46 variants
        • ericzz
          • 286
          #34
          Well it's in . It changes the whole car's feel . Power it unreal and actually not bad at higher speeds . First is very quick but only if you really wind it up .I like it but will hold on to the 325 for awhile before I make a final decision .
