Ebay e36 Turbo Kits
  • ZiMMie
    • Jun 2004
    • 968
    Ebay e36 Turbo Kits
    Anyone know why this kits are soo cheap?
    http://cgi.ebay.com/ebaymotors/BMW-9...spagenameZWDVW
    www.stancefactory.com
  • surebimmer
    • Jan 2004
    • 978
    there's a post\sticky on bummerfourms that say's to stay away from them.
    • matt
      • 3731
      Because they suck and you get what you pay for.
      • static
        • Oct 2005
        • 501
        Zimmie, man, i cannot believe s50 powa is not enough for you anymore
        you just put it in like what, a month ago?
        • matt
          • 3731
          OK, I'll fill you guys in... it's not actually a kit. The only piece of that kit specifically designed for a BMW of any kind is the manifold, which is welded by a robot in china. They are utter crap.
          The "charge pipe kit" contains a bunch of bends of the cheapest available aluminum (try welding it) and a bunch of cheap maybe silicone maybe rubber connectors and t-bolts clamps. Note that none of the pipes have a BOV flange welded on. No intercooler bracket also.
          Even the oil feed kit, which is the EASY part of a turbo kit, is just a bunch of generic fittings that you'll need to stack and adapt to fit the M50.
          The turbo is a no-name brand, probably a knock off master power. (real master power turbos are actually OK)
          Compare their pictures to a proper turbo kit and they don't hold up.
          Note the pipe flattened to run between the pavement and the control arm. Hit a pothole or a bump and you WILL lose this.
          They also flatten the pipe to run under the motor mount. DUH! Every TRM kit includes a fabricated motor mount for perfect clearance.
          Detail of the same area on the TRM prototype car... Nothing lower than the stock suspension.
          And one piece, mandrel bent, perfect-fitting charge pipes throughout...
          Thanks for looking.
          • grib
            • Oct 2006
            • 151
            That's some nice work on the kit above.
            I wouldn't even think about putting an eBay turbo kit on my car. I don't think there was any mention of boost/fuel/timing control above - but that is an absolutely critical ingredient if you want the set up to run further than down the block...
            1987 325i Cabrio - SOLD
            2014 Chevy Volt
            2007 FJ Cruiser
