hfm 3.5 questions concerns
  • ericzz
    • 286
    Ok many of you know I have been battling a ping issue . I had a thought could the EBAY 3.5 hfm I bought on ebay NIB for a 1/3 of the price of others be a bootleg or a regular one with only a larger housing . I just swapped a stock size s50 unit into the car and took it for a ride and I have noticed no difference in the cars performance or the Pinging . I removed the sensor itself from the housing on the 3.5 and it has no numbers on it to verify . Would this cause a ping if it truly is a regular one in a large body ? Would you try the real thing to rule this ? out . THANKS !
  • FredK
    • 14761
    How much did you pay for it? I don't think I've heard of a fake 540 HFM before!
    • Mike B.
      • Jan 2006
      • 987
      Things I would look at if I had knock (pinging) issues, in no particular order:
      - Injectors functioning properly: delivering enough fuel? Sized properly?
      - Plugs: Are they in good shape? Cracked insulators can be a source of pre-ignition. Are the the right temp range?
      - Timing: what is the total advance vs. stock with your chip?
      - Knock sensor: functioning properly?
      - Dyno / Logging Wideband O2: I would be curious to see what my AFR's looked like.
      - HFM: Doubt it's faulty since the stock size still leads to pinging.
      • ericzz
        • 286
        120.00 shipped NIB . funny thing is I can not even find the auction on ebay of my feedback . The guy was in GA , he had a bunch of them now poof he is gone . Anyone know if the sensor is different or just the housing ?
        • matt
          • 3732
          Sensor and housing are both different.
          • ericzz
            • 286
            Anyway to test it to find out if it's the real deal ?
            • matt
              • 3732
              find a bosch part number somewhere on it?
              • ericzz
                • 286
                on housing rf 280 218 800
                on sensor no # at all .
                I pulled the sensor out of a 3" and it clearly reads bosch on the sensor itself unlike the unit I have . I pulled the trigger on a new unit from the dealer the 3.5 euro unit. I will let you know if this corrects the issue of adds any performance . I smell a rat !
                • BeirBrennerE30
                  • 2740
                  if you have a euro hfm and dont have a special chip specifically for it your car will run like crap
                  e30sport.net
                  '06 M3 Competition - 6-speed
                  '97 Range Rover Vitesse
                  • ericzz
                    • 286
                    I have a turner chip and 24# injectors it's all matched !I just think I have some kind of knockoff hfm .
                    • LINUS
                      • 2422
                      If you're still pinging on a real 3" hfm, wouldn't you figure the HFM is fine?
                      Are you sure your chip is for a 3.5" HFM? You gave the other stats, but not that.
                      It's not how you handle the good times, but the faith you keep in the bad that defines you.
                      • ericzz
                        • 286
                        Yes it's the chip tuned for 3.5hfm 24lbs and it's from turner . I am just ruling things out . I am thinking it's a poor quality hfm I know it's not a bosch unit . There was no change in the car form the 3" to the 3.5" I currently have . I am also going to get a 506 dme and try that with stock chip and stock injectors and the 3" hfm .
                        • static
                          • Oct 2005
                          • 501
                          have you tried toluene in gas?
                          • SchnellerVert
                            • Sep 2005
                            • 3948
                            Eric maybe you ought to take a short ride out to Bridgewater and borrow Beir's HFM and ECU to see if it's truely the issue or does someone else have the parts you need nearby?
                            • ericzz
                              • 286
                              Thanks I have the stuff in route allready .
