Dyno results any input ?
ouch..Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
That's a very awkward graph. Not only your air/fuel ratio drops too fast, your torque graph is very, very bad. It should be much more linear and that drop at high end is really unjustified.
Which means, you have a problem somewhere! Check your sensors for starters.It's not an old car. It's an old friend.Comment
Yah this car has me stumped . It runs like a raped ape ! But only issue is this ping . I dyno and get lower than average results . Every sensor other than tps is a brand new factory part . I am getting no codes stored in the DME . I really wonder what is going on here but if there is 10% more HP hidden in this problem I will find it !Comment
What dyno were you using? If it was a DynoDynamics (or whatever) then it WILL be low, but if it was like a mustang dyno or a dynojet, then those numbers are definitely low.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
I had a wrecking yard send me 2 m50's and one s50 when I ordered an s52 for my swap. Needless to say I canceled with them and sourced elsewhere. You sure you've got the right stuff?Comment
Dynos give you rear-wheel horsepower, which is a measurement of the horsepower at the wheels. You can typically add about 15% for drivetrain losses on a manual transmission BMW. So a stock S52 should put out about 210 rwhp. This also can vary depending on the dyno used, weather condition, whether or not a fan is used in front of the car, etc.
The mods listed typically put out about 230whp, by the way.'91 318is
sigpicComment
I garuntee first off from the looks of that graph that your ECU is cutting back timing to prevent knock. I know when I dynoed my car that was happening. Also what diff do you have and what gear did you run it in? I would definately buy either some race gas or octane booster and then run again and see if that smoothes out your netgraph and helps with your #s. When I dynoed my car I think got 191whp with similar mods, but my ECU was cutting the timing back also.Perot isn't a Hillary hater, but he's not a fan either, relating the bumper sticker he received that reads: "Monica Lewinsky's Ex-Boyfriend's Wife for President."Comment
I see, I thought otherwise because most Dyno's here tell you the flywheel HP, only a couple of Mustang's are available which measure wheel HP properly. But the posted charts say 'flywheel torque' and 'flywheel power' which is somewhat strange?Dynos give you rear-wheel horsepower, which is a measurement of the horsepower at the wheels. You can typically add about 15% for drivetrain losses on a manual transmission BMW. So a stock S52 should put out about 210 rwhp. This also can vary depending on the dyno used, weather condition, whether or not a fan is used in front of the car, etc.
The mods listed typically put out about 230whp, by the way.It's not an old car. It's an old friend.Comment
