Questions on Exhaust CAT & ECU
  • BingM3
    • 863
    New your words of wisdom folks:
    I am running no CAT but want to install maybe a universal one, two CATS. Your suggestions where to get them at a good price? I have dual pipes and clearance is my target? They run side by side to each other. Some I see are bulky and may not fit.
    Thinking more of a straight CAT design.
    On ECU, I run stock ECU and stock CHIP, it may be a newbiew question but do factory ECU and CHIP have rev-limiter protection? My tach is from the E30M3 with 6 cyl coded plug and is accurate up to the point when I hot high RPM's seems like it has more pull to do but I let go because of my concern, would the CHIP cut fuel off once I hit peak?
    Any good places in NEW YORK to do an exhaust job? Preferably Long Island or Queens.
    Thanks!
  • BingM3
    • 863
    On ECU, I run stock ECU and stock CHIP, it may be a newbie question but do factory ECU and CHIP have rev-limiter protection? My tach is from the E30M3 with 6 cyl coded plug and is accurate up to the point when I go to higher RPM's---seems like it has more pull to do but I let go because of my concern, would the CHIP cut fuel off once I hit peak? I reach 8k but I do not hear any cutting-off....
    Thanks!
    • NickP
      • 257
      I am running a Magnaflow dual in / dual out cat converter. That's probably your easiest option. The only way I see making 2 cats is to stagger them.
      • BingM3
        • 863
        Can you tell me which model # Magnaflow you got, size of each piping 2" is stock
        • bmws50b30
          • Aug 2005
          • 1151
          bing, i believe there's a shop in whitestone. if that's the guy i know then he is good but expensive. I'll check with my friend.
          1991 330is
          • BingM3
            • 863
            I also see this on ebay, looks good, but checking all options
            http://cgi.ebay.com/ebaymotors/UNIVE...spagenameZWDVW
            • matt
              • 3731
              No it isn't...
