Put my 2002 reservoir in today... not happy with what I did, need some ideas
  • BigD
    • Jul 2006
    • 1085
    Hey guys,
    So I put the reservoir in today and I can't get the lines to work with the reservoir upright without having the lines kink. Cutting them down to length and having the reservoir sit at a bit of an angle works but I don't want to leave it like this. I don't want to put the reservoir any higher than I have it because then it'd be higher than the strut tower.
    Can anyone suggest some 90 deg hoses, where I can get some (a car dealer, or a hardware store)? Guess I'll try to see if I can find a pair of plastic elbows...
    Thanks!
  • kroberts
    • 680
    Loop them. It's hard to explain without a picture. Think of a looped roller coaster, one that does a 360. This will increase the bend radius and prevent kinks.
    kr
    • matt
      • 3732
      Make the bracket longer and make the lines longer.
      • BigD
        • Jul 2006
        • 1085
        The reservoir is already the same level with the strut tower, any higher and it could rub the hood.
        I'm gonna try to find an elbow, but I can see looping the line working too, thanks mate.
        • Mike B.
          • Jan 2006
          • 987
          Extend the lines and relocate the reservoir.
          • LINUS
            • 2422
            D-
            I bet if you look around at what the S14'ers are doing with their res when they install a CF / DTM intake that would give you a few mounting location ideas.
            Seems like Cramer had a detailed write-up in "General Discussion" about 2 months ago. If not here, then poke around on S14.n
            It's not how you handle the good times, but the faith you keep in the bad that defines you.
            • golde30
              • 11464
              i say go with the loop idea. like this:
              IG: @Baye30
              • ZiMMie
                • Jun 2004
                • 968
                cut the lines shorter.
                www.stancefactory.com
                • BingM3
                  • 863
                  Just bend the upper part of the brackets to straighten the stance
                  • tonytony
                    Knee deep in poopie
                    • Jan 2004
                    • 3498
                    or you can go with a DSM reservior, cost me like 5bucks at the junkyard, here's what mine looks like
                    • matt
                      • 3732
                      There's more room there than you think. Make the bracket taller, seriously.
                      • BigD
                        • Jul 2006
                        • 1085
                        I don't want to mess with it. The level sender leads are already pretty much maxed out and I don't want to mess with extending them, moving the mount or making a new one, looping the lines will work perfectly. I tried to make a pair of elbows work but the reservoir nipples are so long that even with only one barb on the elbows, the lines are forced down and torque the fittings.
