reverse lights don't work...auto > manual tranny swap along w/ s52
  • e30polak
    • 6136
    never got around to doing this, but does anyone know the wiring configuration for reverse lights when u switch from auto to manual??? thanks
    INSTAGRAM: @UNDR8D_EMPIRE
  • matt
    • 3732
    There is no wiring needed, the reverse light plug on the chassis is the same auto vs manual. So basically all you need is the switch and the wiring from the switch to the plug, which you can get off any manual 325.
    • Mike B.
      • Jan 2006
      • 987
      Or, keep the E36 reverse light switch in the transmission.
      Run a wire from E36 pin 10 Reverse Lights (blue/yellow wire) to the shifter housing and connect it to the blue/white wire.
      1989 i/is ETM 6322-0 Back Up Lights - shows the wiring very clearly.
      • windnsea00
        • 158
        I need to do this.
        Past: 1991 330is; 1995 318ti; 1993 325is; 1997 318ti; 1989 332is; 1999 Z3 M Coupe
