it looks like I do not have the plug on my harness to connect the e36 oxygen. How should I connect it? The car is running right now just without an 02 sensor. I have a 318is an 92 325i non vanos
oxygen sensor wiring help
None of the wires I mentioned above run to or through the C101/x20. They are all integrated in your E36 harness.
Trace the wires coming out of Pin's 70 and 71 from the DME and terminal 87 on the O2 sensor relay and see where they terminate on your harness.
I think the harness was just snipped, so I would expect all the wires to terminate in a common location.
M52 O2 sensor problems
Hi Guys, still a newbie so sorry if its a dumb question, but has anyone had this problem with an M52?
I have an M52 (OBDII) from a '97 323i auto, I thought it has 3 O2 sensors (2 on headers and 1 just before CAT), thats also confirmed by exhaust diagrams on RealOEM and BMW parts catalogue.
My problem is, I can't find the plug for the 3rd sensor (before the cat). I also had a look on a 528i that was up on a hoist and it has no sensors after the headers. Can anyone shed light on this for me? Could the plug be on the body harness? I could only find a Bentley wiring diagram for the M52B28 from the 328i, it shows 4 O2 sensors (2 before the 2 cats on the split system I guess). I've struggled to find info on M52's in this area, and am getting a bit confused!
Thanks.
