has anyone used an autometer speedo with the stock sending unit
autometer gauges
autometer gauges
Parts for sale http://www.r3vlimited.com/board/showthread.php?t=128440
Car for sale http://www.r3vlimited.com/board/showthread.php?t=118679Tags: None -
im building a new gauge cluster and im just checking if anyone knows if the stock sending unit will workParts for sale http://www.r3vlimited.com/board/showthread.php?t=128440
Car for sale http://www.r3vlimited.com/board/showthread.php?t=118679Comment
what does the computer use the speed sensor to adjust. are you saying if i disconect the gauge cluster it wont work or if i disconect the wheel speed sensor it wont work. thanksParts for sale http://www.r3vlimited.com/board/showthread.php?t=128440
the car will run. but it will not run at full potential. the dme will think your sitting at a stop light, reving your engine. i saw this first hand about 5 years ago. also, it will adjust your idle. the e30 speedo will convert the magnetic pulse signal into a digital signal for the dme and obc. i do know that there are some aftermarket signal converters.....i think dakota sells them. fortunately, the dme will also store it as a fault code, so you at least know whats going on.
quick test..... park car in neutral on hill. rpms near 800. let off brake and let the car start to roll down the hill (car still in neutral). somewhere around 3-5mph the idle will adjust to 950-1000.
cheers, jason
Is there anyway that can be disabled.Parts for sale http://www.r3vlimited.com/board/showthread.php?t=128440
