I need new rods and pistons and I have a set of m3 rods and pistons In my storage shed I think....can I use them in the 2.8 block. I think I'd have to bore the block 2mm but will the pistons and rods work on the 2.8 crank?
s50 rods and pistons in m52???
Tags: None
Yes, you can. Rods are the same length, but pistons are, like you said, larger and will need a bore.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games. -
so that will net me a 2.9 liter right?....not really worth it as the s50 rings are expensive as shit....Comment
I don't know.
To calc the size of one cylinder = Bore^2 x Pi x Stroke (everything in cm and not mm)
The to get the size of the whole engine multiply one cylinder times six and you will get how big it is in CC's. (1000 cc's = 1 liter)
edit: This would be a great way to get a low compression motor for a turbo setup.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
