Another tach question
  • kroberts
    • 680
    Simply stated, If I use a six cylinder coding plug and a 325i tach, my rpm's should be pretty close after the swap, right?
    kr
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    good question, i just finished my swap and my RPMs seem way off. alot more than it says, but i dont have exhaust so maybe it just sounds louder?
    • Mike B.
      • Jan 2006
      • 987
      kr
      Yes.
      • 87-325ic
        • Apr 2006
        • 1198
        what should we do when swapping into an e30 325E?
        get an i cluster?
        • Beej '86 325es
          • 2639
          get an i cluster?
          When I researched this a few months ago, that's the conclusion I came up with. I think the only time you would need to use a different coding plug is if you're changing to an M3 cluster. Someone correct me if I'm wrong.
          -Brandon
          '86 325es S50
          '12 VW GTI Autobahn DSG
          '03 540i M-Sport (sold)
          '08 Jeep SRT-8 (sold)
          For sale:
          S50 TMS chip for Schricks
          • Jason89i
            • Sep 2004
            • 875
            m20"i" clusters - change nothing
            m20 "e" clusters - change to "i" tach and "i" coding plug, or just replace cluster.
            m42 clusters - change to "i" coding plug
            m14 clusters - change to "i" coding plug and change tach faceplate, or buy "inline" signal modifier. search other threads as its discussed in depth.
            cheers, jason
            • devonjordan
              • Jul 2006
              • 2386
              Going from M42 to M3 cluster what would I need?
              Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
              Help a brother out, buy your detailing products here...
              • Rev Engineer
                • Jan 2006
                • 162
                If you're going to use an e30 m3 cluster, then you need to swap the tach section and faceplate from an "i" - being careful not to damage the red e30 m3 needle. Or, you can purchase my electronic rpm converter which converts the 6 cyl tach signal down a 4 cyl signal which lets you keep the e30 m3 tach.
