T-junction instead of tapping the m/s52 head?
  • e30_kid89
    • Apr 2006
    • 489
    Sry too lazy to search, I was faintly remember somebody reading that somebody out there makes some kind of T junction allowing the two required sensors needed for the OBD1 swap the abiliity to run off of the one hole in the cyl. head. Anybody have any details/links?
    TIA
  • 87-325ic
    • Apr 2006
    • 1198
    i thought i remembered hearing something about splicing when it comes to this.
    • RyanZ06
      • Apr 2007
      • 226
      check zionsville.. but it wont be very accurate.
      • E30 Memorial
        • Jan 2005
        • 315
        Steve
        '89 332i
        '90 M3
        '01 530is
        '24 MC JCW
        '13 ZL1 Camaro
        '18 RAM 3500
        • matt
          • 3731
          If it works at all. Didn't on the one swap I tried it on.
          • bwh13
            • Jan 2007
            • 437
            It's easier to just re-thread one of the sensors to the correct pitch. Takes 10 minutes. Uses a file to file off the old threads and use a 12x1.5 die to re-thread the brass body. It works just fine.
            • e30_kid89
              • Apr 2006
              • 489
              Took a look at that zionsivlle adapter, looks like shit. I may just do what that person did E30 Memoroial posted; turn the the single sensor into a dual-plug for the ECT and the gauge. Or i'll just suck it up and get the head tapped.:p
              • BigD
                • Jul 2006
                • 1085
                Splicing won't work. That's only a solution for E36 OBDI conversions because the clusters accept the same signal. You must have the E30 sender.
                I give another vote to rethread the E30 sensor to fit the TB warming nipple hole. My intake isn't on yet, you can come by and have a look. All you need to do after that is to cut off and plug the lead from the spider hose that feeds the TB (the return line for the circuit). I think this is one of those BMW over-engineering things. Volvos are made to operate in some pretty damn harsh winter climates and none of them have any throttle body frost issues.
                Not a great shot but here, note where the brown sensor is:
                • aeryk7
                  • Oct 2005
                  • 616
                  Turner sells one it called a temp sensor adapter i believe and maybe around $40
                  253rwhp
                  My Vids(OLD)
                  http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
                  http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
                  • BigD
                    • Jul 2006
                    • 1085
                    If you're gonna get an adapter, support one of our boys, get it from the Racer's Market (Matt), plus it's only 15 bucks there:
                    • matt
                      • 3731
                      If you're talking about the wiring harness that splits the OBDII sensor into the two plugs for an OBDI car, that will only work for an e36.
                      Thanks for the plug. :mrgreen:
                      • mitch500
                        • Jan 2006
                        • 1092
                        BigD i thought you lived in BC.
                        1988 e30 alpine white vert 5speed
                        1987 e30 325 eta
                        1983 e28 533
                        2001 x5 4.4l
                        1997 e36 M3 Alpine white 5speed
                        1991 Jeep XJ I6 4.0
                        • etxxz
                          • Feb 2006
                          • 2085
                          http://www.racersmarket.net/catalog/...roducts_id=101
                          i was looking at that but it doesnt say anything definite on his description...wonder if this would do it for an s52...
                          No more e30s for me.
                          88 black BMW OBDII 332is dedicated track [sold]
                          88 BMW OBDII bronzit 332is [RIP 03/08]
                          91 BMW 325i [sold]
                          86 Corolla 'Ae86' HB 20v trd [sold]
                          http://youtube.com/watch?v=pTj7Hn9v5Rs
                          • matt
                            • 3731
                            That is for putting an aftermarket gauge sender into the hole for the TB heater.
                            It adapts M12x1.5 threads in the head to a 1/8NPT gauge sender.
                            • BigD
                              • Jul 2006
                              • 1085
                              Oh... you might want to consider one threaded for whatever the E30 sender is (I think it's M12, I think the hole is actually M10... maybe it's M14 then), cause that's an easy solution for S52 E30 conversions. I know above it was said that rethreading the sensor takes 10 minutes but my experience varies from that by a very large amount of time.
