DME / ECU mount
  • 87-325ic
    • Apr 2006
    • 1198
    DME / ECU mount
    why is the 318is mounting hardware used to mount the e36 DME / ECU ?
    is it mountable without this? how much easier is it to get this piece
  • asubimmer
    • 6482
    cause thats what came stock in my car ;)
    idk never heard of ppl not being able to use the holder from a 325?
    • BDSax
      Junkyard King
      • Mar 2006
      • 3594
      because the holder on the 325i/e are build onto the ecu. so there is no seperate piece. you need the 90+ ecu mount.
      • tonytony
        Knee deep in poopie
        • Jan 2004
        • 3498
        zip ties my friend
        • matt
          • 3731
          Or you can buy the whole thing from me. Cheap and easy...
          • tonytony
            Knee deep in poopie
            • Jan 2004
            • 3498
            or you can do that too, i might even do that eventually
            • BDSax
              Junkyard King
              • Mar 2006
              • 3594
              damn, $25? its under $15. or $3 at the junkyard :)
              BRACKET LEFT - 12141727498
              BRACKET RIGHT - 12141727499
              SUPPORTING PLATE - 12141727500
              HEX NUT - 07119922832
              then just use the screws that held in your original ECU.
              http://www.realoem.com/bmw/showparts...23&hg=12&fg=10
              • matt
                • 3731
                We have to keep the lights on somehow.
                • BDSax
                  Junkyard King
                  • Mar 2006
                  • 3594
                  hhahaha, well said. you guys have some nice stuff in that store! hopefully i can make my way up there someday
                  • 87-325ic
                    • Apr 2006
                    • 1198
                    thanks for the responses, perfect.
                    • m_dudey
                      • 267
                      bringing this back from the dead.
                      are you sure you need item #3 and not #5? Or both?
                      • agent
                        Vice Grand Pubaa
                        • 7960
                        Just 1, 2 and 3 in that diagram, and the associated bolts.
                        Originally posted by kronus
                        • Roysneon
                          • 4505
                          Slightly related, does anyone know or have any theories about the validity of the 318 holders grounding the DME through the case?
                          Originally posted by mbonanni
                          I am a pursit now.
                          • pruneball
                            • Mar 2012
                            • 102
                            No, i don't think this is possible. The dme grounds through the harness.
                            • treff-7
                              • Sep 2009
                              • 345
                              As far as I know it does need to be grounded. Lots of people had problems due to improper ground on DME. If you use the late 318 mount it will ground it.
                              I might be wrong but grounding the case won't hurt it for sure.
