getrag vs ZF
  • thuibers
    • Jan 2005
    • 44
    getrag vs ZF
    I blew up 2nd gear in my Getrag 250 [e36] and am thinking of replacing it with a ZF [95 M3] Will this trans fit with my e36 drive shaft? I have a 87 e30 with single vanos M50
  • e30_kid89
    • Apr 2006
    • 489
    No, It wont fit. You need the Driveshaft from t............................
    Just seach.
    • FredK
      • 14761
      No it won't work. The Getrag 250 has a 78 mm guibo and the ZF 310/320 has a 96 mm guibo.
      You'll need to get a E36 M3 four bolt driveshaft, E36 328i driveshaft, E30 M3 driveshaft, or late E30 325e driveshafts with a 96 mm input flange. However, the eta driveshaft will have 10mm bolts, unlike the other driveshafts that I mentioned, which have 12mm bolts, so the fit may not be ideal.
      • e30_kid89
        • Apr 2006
        • 489
        LOL Fred to the rescue...I was going to be nice and help but halfway through I got lazy.
        • thuibers
          • Jan 2005
          • 44
          thanks, I think I will just order a replacement getrag 250 from Bavarian
          • aeryk7
            • Oct 2005
            • 616
            I killed my getrag 250 going into 2nd only couple months ago and just put the ZF in. You will need more parts if you do the ZF , Carrier, linkage, driveshaft, pilot bearing,flex disc.
            253rwhp
            My Vids(OLD)
            http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
            http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
            • MIKe30
              • Sep 2006
              • 2334
              which do you like better now that you've driven both on the same car?
              • static
                • Oct 2005
                • 501
                ^ +1
                my ZF shifts retarded (even tho i have evo3 + dssr), maybe my tranny is just messed up?
