Engine specs ???
  • bostonbmw
    • Nov 2004
    • 429
    Engine specs ???
    I am looking for info on factory specs(Bentley has nothing on the bottom end):
    Main journals
    Rod Journals
    Pistons
    Bore
    Thanks Brian
  • PiercedE30
    • Apr 2005
    • 4220
    Main clearances: 0.0008" - 0.0022"
    Bore: 84.00 mm (total acceptable wear - 0.15mm)
    Ring end gap:
    1st ring - 0.1 - 0.3 mm
    2nd ring - 0.2 - 0.4 mm
    3rd rings - 0.25 - 0.5 mm
    Don't have the rod clearances in front of me or the piston pin clearances.
    Jon
    My 2.9L Build!
    • bostonbmw
      • Nov 2004
      • 429
      I don't think those are for an S52 (which I forgot to mention) anyone have engine specs ??? Or know where I can get them. I want to get the bottom end together this weekend....
      • bostonbmw
        • Nov 2004
        • 429
        Does the BMW TIS have detailed engine specs (piston ring gaps,main bearings etc...)?
        • PiercedE30
          • Apr 2005
          • 4220
          I believe it does. I will check.
          shit, can't check. don't have/know where the cd is.
          My 2.9L Build!
