Do people use the OEM oil cooler with thier swap?
  • SL33PER
    • Aug 2007
    • 70
    I know there is no 'direct fit' for the OEM e30 oil cooler, but when doing the 24v swap, does anybody plumb the OEM cooler into their system? I'm going to be boosted, so I think it would help greatly with oil temps.
    I'm thinking:
    Filter->Cooler->Turbo->Motor
    • 37833
    It would probably be just as easy to run a nice aftermarket cooler that will probably work much better.
    Grover Beach, California
    BimmerHeads.com
    • matt
      • 3732
      That won't work anyway. Try running an oil coolers worth of oil through a turbo and all your oil is going to leak out your exhaust. If you run a turbo's worth of oil through an oil cooler, it won't be enough volume to effect your oil temps at all.
      • PiercedE30
        • Apr 2005
        • 4220
        I am. I am using a modified S52 (MZ3) housing with -10AN lines to the original oil cooler.
        My 2.9L Build!
        • grib
          • Oct 2006
          • 151
          You might start with an oil temp gauge first and see how it goes. Mine usually hovers around 205 - 215 deg F.
          1987 325i Cabrio - SOLD
          2014 Chevy Volt
          2007 FJ Cruiser
          • Bmjpv
            • Mar 2007
            • 561
            Factory oil cooler w/24v
            On my builtup s52 swap into 88'is I used the euro filter housing and ran #10 AN lines to OE cooler. I also have the M3 oil gadge which shows 180-190F running down road, in Florida traffic maybe 210F.. I found it lowered 20F by running the OE cooler ,After market cooler might work better but my OE cooler fits very nicely . Just Do it !
            • Mike B.
              • Jan 2006
              • 987
              ORME Bros.- http://www.ormebrothers.com/ - has metric to AN fittings (M18 Female to AN10 Male) that allow direct attachment to the cooler. No need to mess around with a hydraulic shop adapting the stock lines.
