Hey guys,
I picked up the s52 swapped e30 yesterday. Car got me all the way back to Virginia Beach from PA without and significant problems.
One of the things that sucked though was the heater would only work when the car was idling at slow speeds, at higher speeds (highway cruising) it didn't work and with the 40 degree temp last night it sucked.
Before Mike sold the car to me he was trying to fix the temp guage because it wasn't reading correctly. According to the temp guage the car runs very cold the whole time (stays in blue) and based upon the heat I would say thats pretty accurate. Mike replaced the Thermostat but it didn't solve the problem.
Something I noticed is that when ever I accelerate I smell coolant coming in through the vents and this is when the heat is semi-working. Could there be something wrong with the water pump? Or maybe the cooling system was just bled incorrectly... I'm not sure what the cause is so if any of you have any ideas please shoot them my way.
Oh also, supposedly this car is missing a few groundstraps on the coil packs, I believe its cylinders 1 and 6. Would this be causing the rough part throttle acceleration or is that because of the coolant system problems?
Thanks,
Jeff
Thanks,
Jeff
