Longer Throttle Cable?
  • rob_e30
    • 456
    I'm posting this here because I think this group may know the specifics...
    I need to know if the E36 or E30 M42 throttle cable is longer than the stock E30 M20 throttle cable and if so by about how much?
    I need a slightly longer throttle cable for the turbo M42 with an M20 throttle body in a custom position and the stock M20 cable is a bit too short.
    Thanks,
    Rob.
  • Mike B.
    • Jan 2006
    • 987
    E30M3 cable is longer than the stock E30 M42 cable. Not sure about how much longer as I don't have the M42 cable anymore.
    • BDSax
      Junkyard King
      • Mar 2006
      • 3594
      for the 24v swap i used a e34 cable, i think its longer
      • KangamangusDriver
        • Aug 2005
        • 1870
        I used the E36 cable, once installed I realized that the M42 cable would of worked as well.
        As a matter of fact the E36 cable was a bit too long, I had to shorten it!
        • rob_e30
          • 456
          So the M20 cable was too short?
          • dude8383
            • Jan 2005
            • 10387
            Sorry to bring this back from the dead...
            But I ordered the E36 throttle cable because I thought I had to get matching stuff for the motor..
            How did you shorten yours? Do you think it can still work even if its a bit longer?
            I've seen others getting E34 throttle cables and I'm curious to know what the difference is!
            • rob_e30
              • 456
              I used an E30 M3 cable and it worked great.
              • dude8383
                • Jan 2005
                • 10387
                Did some more reading on the site and found out the E36 throttle cable works as well!
                Thank you :)
                • e30s52
                  • Oct 2007
                  • 5235
                  can you use the m20 cabble?
                  www.gutenparts.com
                  • Charlie
                    kid tested, administrator approved
                    • 6686
                    For a 24v swap? No. It's too short. I ran the m42 cable, it's a good length, easy to position.
                    -Charlie
                    Swing wild, brake later, don't apologize.
                    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                    FYYFF
                    • e30s52
                      • Oct 2007
                      • 5235
                      lame. i was wishing that i would have to buy anything else :(
                      www.gutenparts.com
                      • ZiMMie
                        • Jun 2004
                        • 968
                        -Charlie
                        M20 cable its actually long and u will need a small spacer for it to work on a 24V.
                        Ive converted about 6 E30s to 24V's they all used stock cables.
                        2 M42's
                        4 M20's.
                        ALL STOCK CABLES! On a 91 318's It fit Perfect. No spacers were needed.
                        www.stancefactory.com
                          • 37833
                          I'm using an E34 cable, it works fine but there's got to be a better option out there. It kind of collides with the iX booster.
                          Grover Beach, California
                          BimmerHeads.com
                          • e30s52
                            • Oct 2007
                            • 5235
                            did you put the cable in before you put the motor in or could i put the motor in and if it is to long or short put the e34 cable in with out taking the motor out again?
                            www.gutenparts.com
                              • 37833
                              Dude, throttle cables aren't THAT complicated, of course I put the motor in first.
                              BimmerHeads.com
