M50...vanos or NV...m3 cams?
  • JRKOUPE
    • Dec 2004
    • 3159
    Hey...Im getting interested in swapping.....Im tired of crappy drivers w/ more hp passing me at the track.
    Re m50's.....
    are any years best?....
    V or NV?
    has any one tried the m3 cams in theirs?......its supposedly good for 225 hp or so w/ the proper software....
    Illl do some searching now
    tia!!!
  • matt
    • 3732
    I have M3 cams. Very nice mod, but yes, you need software. I made a pull on stock software... it was terrible.
    Not sure about 225hp... I am getting 185 at the wheels, which is pretty weak actually. I think my cam timing is off a bit. I would guess 195-200 at the wheels would be more typical.
    We have chips for M50 w/ S50 cams on the site. Let me know if you have any questions.
    Edit: I just realized you're asking about swapping the motor, not just the cams. Use a vanos motor or don't bother. A lot of people will tell you to use an M motor or don't bother, but I don't agree with that.
    • asubimmer
      • 6482
      yeah use the vanos motor. I have one out of a 94' 325i but it doesn't really matter which you get it out of. Its easier to find them out of a 3 but you have to change the oil pan. But w/ a 5er you have to change the arms and the harness is shorter...
      I prefer the 3 24v but its all about what you would rather change to put it in. My car has the stock cams for now, looking for some group n's ;) But I am swaping another e30 to 24v in a month or so and it will have the s50 cams. It will be running off Korman software as does mine.
      Hope that helps
      • JRKOUPE
        • Dec 2004
        • 3159
        swap
        Good to see responses from some guys " in the know"......thanks!!!!!
        185 at the wheels is like 30- 40 over a stock m20.....sounds good enough to start.
        Should I look at s 50(obd 1) cams only, or are obd2 s52 cams fine as well?...
        • asubimmer
          • 6482
          You can use s52 cams in a m52 directly but w/ a m50 you need the cam trays as well. So yes they will work in an m50.
          • JRKOUPE
            • Dec 2004
            • 3159
            ok got it.....Im learning here.
            So m50 w/ s 50 cams you do NOT need cam trays?...
            Im assuming vanos m50 engines started in 93?.....
            thnx!!!
            • asubimmer
              • 6482
              yes and yes
