Originally posted by windsor318is
View Post
As for the coolant hoses, i am sorry but i don't have my car or i would take apart my intake manifold and take pictures for you.
What you can do is get vacuum plug sealers and plug your coolant lines (the thin smaller one on you metal cooling pipe) and your 2 plugs on the throttle body. For the small metal pipe on the metal coolant hose, you want to make sure you tie down the vac cap with a metal clamp so pressure doesn't push it off (the ones you use for rad hoses and stuff)...
![](http://www.bfyobsoleteparts.com/files/master/thumbs/t_9545.jpg)
Anyway, now what I did for the e30 temp sender is I got a brown top e30 temp sensor and dyed it so it can fit in the hole that gives coolant to the throttle body.. does that make sense? I'm trying to explain it the best I can. I wish I had my car so I can take pictures!!!!! :hitler:
-Abe.
