Hey man-you shouldn't be running with 87 gas! Were you pinging at all? Maybe pull the valve cover and recheck your timing.
How old is the o2 sensor? Although you usually tend to run rich when these go out.
Check all your vacuum lines. A leak might cause it to run lean.
Are you sure you're running super lean?
