I have a dead OBDI crank position sensor from an S52 swap. I am doing the OBDI conversion. I am little pissed at myself for not testing the resistance of it before I decided to twist the top where the wire is at for it to be able to line up right, so I don't know if that is what caused it.
So internet, is that what I am supposed to do in the first place for it to fit on the S52? Because the wire inherently does not allow the sensor to be lined up correctly in the first place. My other question is will an OBDII crank sensor work? (From the looks of it I will have to extend the wire from the harness for it to reach)
Also, does it absolutely need to be lined up correctly? can I rig it up to just be there and have it work fine? The little tab at the end of it seems to indicate that it does need to be lined up at the correct angle however...
