is it really worth gathering the parts for swap?
  • windsor318is
    • Mar 2004
    • 688
    heres the situation, im thinking of buying a hole wack of stuff from zionsville, but i wanna know really if its worth wasting the time searching and waiting for parts? im thinking of buying these, what do you guys think i would save if i just waited and boaght the parts here and there when i could find them? could i finish by next summer, come april maybe?
    here:
    You have 4 item(s) in your basket totaling $3,121.95
    Code Product Quantity Price/Ea. Total
    EEEMC Project Orca Engine Mounting Components $895.00
    EECS Project Orca Cooling System $582.00
    NP-POBDI Project Orca / OBDI Conversion Bundle $149.95
    EOCK OBDI Conversion Kit $1,495.00
    Subtotal: $3,121.95
    p.s. i dont really need the cds....
  • matt
    • 3732
    you could get all that stuff for $1k with a little patience and luck. Maybe more if youre really set on an aluminum radiator.
    • ericzz
      • 286
      I bought a 93 525i running for 600.00 and used the obd1 oil pan harness ecu and loads of other stuff . Then sold the shell for 600 to a local yard .
      • static
        • Oct 2005
        • 501
        as usual it's a tradeoff between: money-time-effort
        i'd say there is no rush as the spring is still far away.
        • Rev Engineer
          • Jan 2006
          • 162
          I second that...
          • vr4boy
            • 282
            same boat for me...bought an m50 off a 525i and used all the components to convert my s52 into obd1 including the oil pan-$450 for the motor(sold long block for $350)...
            be patient and buy when parts pop up on here,ebay,e30tech or bfc...
            also,no need for the project orca cd etc-all info on the swap is on here-tried and prooven...gl
            • windsor318is
              • Mar 2004
              • 688
              alright.....i guess you guys are right, ill get stuff here and there, im not rich either id rather not drop that kind of money. the oly thing i think is worth buying is the obd1 conversion, im not even sure what a parts list for it is anyways, anyone know? 1500 bucks doesnt seem that bad.
              • So Live
                • 2512
                Buy a full complete obd1 m50 with all the components and you will be set and for a lot less money and youll have your oil pan parts if you get it out of a 5 series. It dosnt even have to be running.
                Ps. are you from windsor, CT? im about an hour from there.
                -Chris
                • e30polak
                  • 6136
                  sourcing parts will save you a good deal of money, despite the time put in to looking for them. it's totally worth it...in my parts search i even came upon a 3.5 hfm($35), m50 intake mani w/t-body($65), e34 oilpan($35)...basically u can get parts way cheaper at the junk yard then what u will pay for the same stuff from Zionsville
                  INSTAGRAM: @UNDR8D_EMPIRE
                  • windsor318is
                    • Mar 2004
                    • 688
                    i guess ill start searching part by part then, im from windsor ontario canada, not CT. i might do just that im sure i can find an m50 out of a 525 for cheaper than the $900 kit they sell. never thought of that....
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      I suggest a shop that installs used engines, my shop did two 325is' and I sourced all the parts off the floor of my shop for free. I ordered the 525i m50 engine and swapped pans off the e36.
                      • BingM3
                        • 863
                        here:
                        Subtotal: $3,121.95
                        Buy a car or entire engine, save you a lot of waiting and work
                        • BeirBrennerE30
                          • 2740
                          you can get all that stuff from the dealer with a CCA discount for MUCH MUCH cheeper and have brand new oem parts... a lot of the stuff from zion isnt new even though they are great to deal with...
                          e30sport.net
                          '06 M3 Competition - 6-speed
                          '97 Range Rover Vitesse
                          • e30_kid89
                            • Apr 2006
                            • 489
                            Very true.
                            I have almost all the swap parts incl. OBD1 swap stuff and minus a DME and i've just topped $550. Mind you i got some really good deals, like ripping this guy soo bad on CL for the 525i pan. He knew nothing about it so i only ended up paying $25 for the "Useless piece of metal"
                            Waiting for parts FTW.
                            • windsor318is
                              • Mar 2004
                              • 688
                              so its probably still cheaper to order from the dealer? i do get discount, usually 5% over cost.
