Hey guys,
I have been having on-going problems with my clutch system. My clutch will engage just fine most of the time and then sometimes when I let the clutch pedal out from a stop the clutch engages very early but only part way and is like that for 2-3 inches of clutch travel. After this if I put the car in nuetral and pump the clutch once it goes back to normal again. I was thinking there was a problem with air in the system but I keep bleeding the clutch and I still have yet to see any bubbles. I just pressure bled the system tonight and for some reason it feels like its almost worse now then before.
Do you guys think the master cylinder is going on the car or could it be the slave cyl? I believe the slave is original on the engine and has about 70k. The master on the other hand could be originial and the car has 215k.
Anyone have any ideas?
TIA
Jeff
TIA
Jeff
