My m50 dyno.. good or bad?
  • zav3n
    Curious George!
    • Mar 2007
    • 223
    i dyno'd my car this morning. its a 95 m50tu with: ebay headers, 2 1/4 piping, single resonator, magnaflow exhaust, m20 flywheel/clutch, intake, and a chip. no a/c, but it does have power steering. i got 159 first run, 174 2nd run, and 180 3rd. what do you guys think and has anyone else done an M50 dyno (not S50).
    this is the graph's:
    (sorry bout the quality its from my phone)
    let me know what you guys think..
  • matt
    • 3732
    Not a bad peak number, if it can be trusted.
    Graphs are strange. We don't usually see such a dip at 4200. What kind of software? Did you put your motor together yourself?
    • zav3n
      Curious George!
      • Mar 2007
      • 223
      the dyno can be trusted i know that for a fact ,dinan chip for now but im gunna get your software once i get my s50 cams, i was wondering what that dip was at 4200... and yes i put it together with help from MR 325, Asubimmer, and TNG auto
      • matt
        • 3732
        Not sure exactly what that is... could be knock, could be software, could be cam timing...
        • zav3n
          Curious George!
          • Mar 2007
          • 223
          what do you mean by knock like rod knock or like knock sensor?
          • matt
            • 3732
            Knock like detonation.
            • grib
              • Oct 2006
              • 151
              Those numbers are not bad compared to what I have seen before on the BFc forums.
              Why was there such a large difference between the first and third runs? Usually power decreases as the engine heat soaks. Did you change anything between those runs?
              1987 325i Cabrio - SOLD
              2014 Chevy Volt
              2007 FJ Cruiser
              • 318isbmw
                • Nov 2005
                • 2843
                Could be he started way below optimal temp and it warmed up by the 3rd run.
                • zav3n
                  Curious George!
                  • Mar 2007
                  • 223
                  ya it was early i the morning and it finaly warmed up by the third run. personally i think if i did a fourth it would but a little higher
                  • zav3n
                    Curious George!
                    • Mar 2007
                    • 223
                    if anyone interested heres a video of it on the dyno
                    • Glaede
                      • Oct 2007
                      • 138
                      I know that my engine puts out 198,8 hp (on the motor...).. Its a M50 2.5 liters with M3 headers, exhaust and K&N airfilter. I don't know if you can use that information for anything?
                      • Jason89i
                        • Sep 2004
                        • 875
                        just a shot in the dark..... but it looks like they changed gears. rpm vs. road speed.
                        cheers, jason
                        • PiercedE30
                          • Apr 2005
                          • 4220
                          Why didn't they do an AFR graph? All I see in the area where it should be are two lines that don't look like an AFR line.
                          My 2.9L Build!
                          • SpecM
                            • Oct 2005
                            • 4531
                            -Hmm "m3 headers" = 325i manifolds?
                            1989 cirrisblau-metallic 325i
                            • ed94r
                              • Mar 2004
                              • 382
                              I hate to do it.....but the graph and dyno runs are in STD mode. Maybe you can contact the dyno operator to bring up your file and do the SAE conversion. It's the only way to compare to others graphs, which are mostly SAE.
                              I don't suspect you'll lose too much, but be prepared.
                              Ed
                              1988 E30/S50...now with S52; Track
                              1994 Miata R; ES Solo2
                              1998 Lexus LX470; Wife (Slee'd anyway)
                              2002 BMW 530i; A+ Commuter
                              2002 BMW 325iT; Sport/Premium 5-speed
                              2011 21' EconoTrailer
