I'm in the process of converting an S52 to OBD1 and I'm wondering about the need to use the S50 coolant hose - the (4) ended hose that connects the water pump/throttle body/expansion tank.....
Turner Motorsports sells the adaptor for converting the water pump to the barbed fitting for this hose.
My question is what is the advantage of converting to this hose? It appears the S52 hoses run to the same locations less the inline thermostat for the throttle body. Is this thermostat needed for the OBD1 conversion or is it that the S52 metal piping gets in the way of mounting the OBD1 intake manifold? Thanks for any info.
