Fuel Rail question
  • 318isbmw
    • Nov 2005
    • 2843
    Fuel Rail question
    On looking at my fuelrail, it doesn't have a spot for the regulator to mount. It fits perfectly and matches exactly as it should with the m50 and I need to get a regulator figured out. Is the regulator mount built into the rail or does it bolt on? Also, how does it measure if it doesn't have a hole into the rail.
    Thanks
  • surebimmer
    • Jan 2004
    • 978
    Sounds like you have one from a S/M52. Is it silver and have a schrader valve on the front on the rail? If so its a late model one.
    The one you need should have a spot at the rear near the firewall that the regulator drops into and then you clamp it in place.
    • 318isbmw
      • Nov 2005
      • 2843
      Nope, no schrader valve and its black. And yes I believe it is an m52 I found out. I'll just get the regulator for the m52 and just put it inline, not a huge deal...
