my new e30 m50
  • 0000000000
    • 473
    my new e30 m50
    I just bought a new m50 86 325ES, the m50 came out of a 92 525i. I have a few questions about the car:
    Is the motor a vanos or non vanos?
    What pin on the ECU is the Check engine light because mine isnt on when i put the key in the frist position?
    What gauge cluster can I use?
  • 318isbmw
    • Nov 2005
    • 2843
    If its a 92 then it should be NV
    No idea on the pin, depends on the car, sorry I dunno bout that one.
    What do you mean by what cluster? Are you wanting custom or m3, otherwise its stock one. Personally I'm wanting the m3 one since it has the oil pressure rather than mpg on it. Not that its incredibly accurate, but someday I'll go w/ a custom setup.
    • matt
      • 3732
      no, it has oil temp.
      • 0000000000
        • 473
        Ok so i can just use any stock cluster that i will work.
        • turboeta
          • Aug 2007
          • 571
          Yeah just use your stocker, no need to change it..
          635csi Euro/Alpina B7S
          • 318isbmw
            • Nov 2005
            • 2843
            My bad, new info to me...
