M50 Into 318is
  • Majjic
    • Jan 2008
    • 150
    M50 Into 318is
    Hey guys
    i got a few quetions if you dont mind :)
    i got a 95' vanos m50 325i (100,00 KMS) ;) im putting in my car ...91' 318is
    the m50 is an auto tranny so im planning on using my m42 tansmission, e36 325I driveshaft (as far as i know i will need) and my e30 4.10 LSD
    good combination??
    im trying to budget my spending limits since i have to pay for everything else lol
    i would like to do the "m20 flywheel" upgrade, im pretty sure it will work from what i have searched. does anybody know the part numbers for the flywheel!
    im just trying to double check everything before
    What are my options??
    thanks for the help!
    - 88' E30 M3 -
    - MKV JETTA TDI -
  • dude8383
    • Jan 2005
    • 10387
    I believe that you need to use the E36 transmission in order to pair it with the E36 driveshaft.
    Not sure about what driveshaft you need to use with the Getrag 240 though.
    • BigD
      • Jul 2006
      • 1085
      Will the 240 even fit?
      • FredK
        • 14759
        I believe 02stu got a 240 to work somehow.
        • 318isbmw
          • Nov 2005
          • 2841
          Yes, the late model 240 behind the m42 will work w/ the m50. You need the e36 325i driveshaft and e30 325i selector rod and shifter though. The 4.10 will end up abit high reving at highway speeds and top out quickly because of the stock gears. I've read 3.73 is the best for middle of the road setup. Also, the small case I doubt would hold up to the increase in torque, if you launch it hard, I'd be worried.
          • e30_kid89
            • Apr 2006
            • 489
            240 will work.
            Use e36 325i drive shaft
            m20 ltw flywheel/clutch combo will work
            3.73 LSD
            • Majjic
              • Jan 2008
              • 150
              lol whats hard? 3,000? lol
              - 88' E30 M3 -
              - MKV JETTA TDI -
              • Majjic
                • Jan 2008
                • 150
                Originally posted by e30_kid89
                240 will work.
                3.73 LSD
                where can i find a 3.73 LSD?
                what car do they come from?
                - 88' E30 M3 -
                - MKV JETTA TDI -
                • dude8383
                  • Jan 2005
                  • 10387
                  search is your friend my man.
                  • FredK
                    • 14759
                    All 325 'is' models had S3.73, except for later (airbag) automatics which had a S4.10. The M3 also had S4.10
                    • e30_kid89
                      • Apr 2006
                      • 489
                      Oh and you can re-use your m42 radiator. You'll need to run an electric fan though, which is a nice upgrade deleting the engine driven fan. More cleaner than running the later m20 cooling system.
                      • Majjic
                        • Jan 2008
                        • 150
                        Im planning on using a rad from a e36 325, got it for free :grin:
                        - 88' E30 M3 -
                        - MKV JETTA TDI -
                        • zav3n
                          Curious George!
                          • Mar 2007
                          • 223
                          im currently running a m50 with:
                          getrag 240
                          e36 325i manual driveshaft
                          m20 flywheel clutch
                          i had a 4.10 but upgraded to a 3.73 LSD
                          works great i really felt a difference when i upgraded to the 3.73 + its really fun on the track too...
                          • Majjic
                            • Jan 2008
                            • 150
                            what do you guys think about a 2.93 LSD?
                            im not too familiar with diff's anywase
                            - 88' E30 M3 -
                            - MKV JETTA TDI -
                            • Van Westervelt
                              • 9365
                              2.93 will be too low.
                              M20 starter on this one as well? Matching it with the flywheel? (speculating here)
