Members with swapped cars
  • SchnellerVert
    • Sep 2005
    • 3948
    Why don't we do a Parts summary of how each members running/ driving swap car is with parts # and or source of parts to get rid of some confusion.
    I'm sure there will still be some. But it might help.
  • turboeta
    • Aug 2007
    • 571
    Good idea, it would be a really good addition to the DOHC sticky
    635csi Euro/Alpina B7S
    • e30_kid89
      • Apr 2006
      • 489
      The parts that people use are too common, there would be a few differences like exhaust, motor mounts, shimming or no, brake booster/MC/reservoir, transmissions and obviously the motor you use for the swap. all of it has been covered so they should just use the search function.
      • WillisE30
        • Jan 2007
        • 831
        Yeah and every swap turns out just a little bit different. Some people use shims, other don't. Some people have to shave the fins on the intake manifold, others don't. Same with practically everything else. Even the simple stuff like motor mounts has lots of variance.
        In the end all you're doing is tossing an e36 motor in the car with some E28 mounts, and an E21 brake booster(or whatever else you feel like). It's a pretty simple swap.
        sigpicFormer professional wrench thrower.
        Current:
        1988 325is S52
        Former:
        2008 Sparkling Graphite M3 Sedan(victim of home ownership)
        1988 M5
        1996 328is
        • BDSax
          Junkyard King
          • Mar 2006
          • 3594
          i planned on doing that when i started my swap. kept up with it but it just got to be to much and i forgot. this is what i have.
          Date Item Part Number Price
          09/10/06 Motor $140.00
          09/10/06 Motor Core $20.00
          09/10/06 Engine Wire Harness $15.00
          09/10/06 Motor Mount $10.00
          09/10/06 DME (Computer) $15.00
          09/10/06 DME Core $2.00
          09/10/06 Junkyard Labor $40.00
          10/16/06 Oil Pan/Oil Dip Stick $54.24
          10/26/06 Vanos Oil Line 11-36-1-703-464 $32.18
          10/26/06 Head Gasket Set 11-12-9-064-467 $107.57
          10/26/06 Water Pump 11-51-7-527-910 $44.64
          10/26/06 Thermostat 11-53-7-511-580 $20.16
          10/26/06 Thermostat Housing 11-53-1-722-531 $20.48
          10/26/06 Belt Idler 11-28-1-748-130 $24.55
          10/26/06 Seal Ring RAL 14x18 $1.30
          10/26/06 6- Spark Plugs NGK 2288 $23.28
          10/26/06 Motor Mount 11-81-1-132-793 $49.00
          10/26/06 Oil Pressure Sender 12-61-1-710-509 $6.76
          10/26/06 Water Temp Sensor 13-62-1-709-966 $11.66
          10/26/06 Pilot Bearing 11-21-1-468-742 $5.27
          10/26/06 Cooling Hose 13-54-1-735-173 $14.60
          10/26/06 Cooling Hose 13-54-1-735-174 $9.27
          10/26/06 Radiator Hose 11-53-1-726-344 $15.04
          10/26/06 Radiator Hose 11-53-1-708-499 $11.48
          10/26/06 Navel Jelly $3.15
          10/26/06 Engine Paint $7.82
          10/26/06 Paint $3.48
          10/26/06 Permatex Moto Seal $4.89
          11/01/06 Tranny,5 Speed Swap $100.00
          11/01/06 Bottom End Gasket Set 11-11-9-064-460 $89.62
          11/01/06 Exhaust Studs 11-12-1-744-057 $5.76
          11/01/06 Exuast Nuts 11-72-1-437-202 $9.60
          11/01/06 Bolt and Washer 07-11-9-901-787 $0.48
          11/01/06 Gasket 11-41-1-703-947 $1.40
          11/01/06 Suction Pipe 11-41-1-748-150 $23.60
          11/06/06 Driveshaft Center Bearing 26-12-1-225-152 $34.01
          02/21/07 M8x1.25 Helicoil Kit $31.93
          03/12/07 Clutch Release Arm 21-51-1-204-229 $7.41
          03/12/07 Clutch Pivot Pin 21-51-1-202-659 $0.72
          03/12/07 Clutch Kit KF296-01 $184.25
          03/12/07 Clutch Slave Cylinder 21-52-1-116-300 $39.20
          03/12/07 Clutch Master Cylinder 21-52-1-156-000 $63.19
          03/12/07 Guibo 26-11-1-225-624 $35.19
          03/12/07 Shift Lever Bushing 25-11-1-220-600 $5.09
          03/12/07 Selector Rod Washer 25-11-1-220-439 $0.84
          03/12/07 Input Shaft Seal 23-12-1-220-619 $7.20
          03/12/07 Output Seal 23-12-1-205-340 $5.51
          03/12/07 Brake Resivoir Grommet 34-31-1-163-464 $3.16
          03/15/07 Brake Resivoir Grommet 34-31-1-163-464 $3.35
          03/15/07 e34 Throttle Cable 35-41-1-160-609 $23.04
          03/15/07 spring 21-51-1-204-327 $1.10
          03/15/07 Circlips 25-11-1-220-379 $1.24
          03/15/07 Bushing 25-11-7-519-669 $6.64
          03/15/07 Shift Lever Bushing 25-11-7-527-252 $51.16
          03/15/07 Wiring Cover 51-71-1-380-391 $13.92
          03/15/07 Wiring Cover 51-71-1-380-392 $18.76
          03/15/07 Bolt 11-22-2-243-051 $1.80
          03/15/07 Connector 11-61-1-738-629 $4.00
          03/15/07 Mount 11-12-1-730-356 $26.16
          03/15/07 Rubber Boot 13-54-1-738-757 $16.32
          03/15/07 Hose 13-41-1-738-186 $10.96
          03/15/07 Hose 13-41-1-738-185 $8.48
          03/15/07 Remote Brake Resivior 34-32-1-160-576 $72.68
          03/15/07 Tranny Bolts 23-00-1-222-890 $1.72
          03/15/07 Tranny Bolts 23-00-1-222-893 $1.72
          03/15/07 Tranny Bolts 23-00-1-222-887 $3.44
          $1,627.47 Total
