Engine going in
  • Van Westervelt
    • 9365
    Very well played sir! I wanted to do it this way, but I had my 88 sitting in the gravel at an angle. Shoulda pre planned. Next time for sure tho. (month or two)
    • e30serg
      • Dec 2006
      • 562
      Hey-is there another factory hoist eyelet on the rear of the engine? I can't see the rear of my engine yet-it's still in the donor!
      • kroberts
        • 680
        I dont know that raising the back of the car so high was really necessary. I did it as a precaution, so I would have to stop midway through the installation process and lift the back end. Whatever you do, dont set the ass end on jackstands and lift the front. That seemed like an invitation to drop the car.
        • kroberts
          • 680
          Serg, yes its above the starter, by the head coolant port. It's pretty thick.
          • e30serg
            • Dec 2006
            • 562
            Heh-that is exactly the reason I still have the rear end of the donor on the car. I'm not a fan of working under a car up on 4 jack stands with no wheels on. I was just going to drop the engine onto a pallet (like yours), lift the front of the car up and slide the engine/tranny combo out. I do have the whole front end removed, so no radiator or front crossbrace to worry about.
            • e30serg
              • Dec 2006
              • 562
              Thanks!
              • scabzzzz
                Estado de mierda de encargo
                • 6871
                I would eat off that S52. Well played sir.
                • windsor318is
                  • Mar 2004
                  • 688
                  i noticed you smoothed out the rubberized mess around the shock towers before painting, did you bondo them as well?
                  • SchnellerVert
                    • Sep 2005
                    • 3948
                    Been debating using this process on next project with the Eta. But will use a lift.
                    • kroberts
                      • 680
                      I did a little smoothing and cleaning but not to the extent that you could say I smoothed the engine bay. I just tidied the place up a bit. I scrapped the heaviest factory seams and re-applied some 3M seam sealer with a little less enthusiasm than they did originally. No bondo.
