m50 86 325es
  • 0000000000
    • 473
    m50 86 325es
    I have a problem with the engine oil low level light its always on but i know i have enough oil.
    Where do i look frist.
  • turboeta
    • Aug 2007
    • 571
    Step one.
    Take bulb out.
    635csi Euro/Alpina B7S
    • 0000000000
      • 473
      That doesnt fix it, i want my low level light to work.
      • mentaleeill
        • 850
        that light really sucks anyway. buy a oil press. gauge and check your oil periodically if you wanna be accurate.
        • 0000000000
          • 473
          i still want it to work though thats the thing
          • 0000000000
            • 473
            anyone?
            I didnt do the swap so thats why im asking.
            • e30s52
              • Oct 2007
              • 5235
              i would go with just pulling the light and putting a gauge in. but do you have an oil light reset tool?
              www.gutenparts.com
              • 0000000000
                • 473
                no i dont, but its the light on the roof, I just want to know what sets it off so i can go and make sure it works, if no one else knows of this than i will probably just take it out.
                The reason im asking is that when the swap was done is this just another thing that happens besides the MPG gauge, that the low leval light turn on?
                • matt
                  • 3732
                  My MPG gauge works.
                  • Mike B.
                    • Jan 2006
                    • 987
                    To have the check panel work properly, you need the E34 oil level sender that mounts in the oil pan. 3 wires to hook up after the sensor is in place (static/dynamic/ground). The diagram is floating around this forum someplace in an x20/c101 thread.
                    • Jason89i
                      • Sep 2004
                      • 875
                      the mpg gauge should work (if wired correctly) but will be off. mpg gauge is dependant on injector pulse. change to a different injector flow rate (as m20e to m50) and it will be inaccurate.
                      for what ever reason, most people do not wire up the check panel oil level light. dont ask me why. however, its really really easy. get a 3 wire plug that plugs into the oil level sensor, then grab a wiring diagram and match up the e34 to e30 wires. you have to match dynamic, static and ground wires.
                      do a search. im sure ive posted the pin locations / functions / directions before.
                      cheers, jason
                      • 0000000000
                        • 473
                        Originally posted by matt
                        My MPG gauge works.
                        How do you do this?
                        • e30s52
                          • Oct 2007
                          • 5235
                          like the rest of us
                          www.gutenparts.com
