Is it really necessary to use hose clamps on the plastic adapter between the spider hose and the overflow tank hose? I figured I could get away without any for now to just test the system since that part sees no real pressure. Thankfully I put in only a bit of coolant, to check bit by bit. And that juncture leaks like a sieve! I hurried to put on a hose clamp on the overflow tank side figuring since the adapter came with the spider hose it can't be leaking there... wrong. So pretty much all of the coolant I put in ended up on the floor bit by bit. Fuck. I don't really even see a hose clamp helping so much if it isn't watertight with 0 pressure (and undiluted coolant is pretty damn viscous too). This can't be right...
Spider hose leak
Originally posted by BigD View PostIs it really necessary to use hose clamps on the plastic adapter between the spider hose and the overflow tank hose? I figured I could get away without any for now to just test the system since that part sees no real pressure. ...
your saying the cooling system sees "no real pressure...."
put a clamp on it. stop joking around. cheers, jason
Originally posted by Jason89i View Postyour kidding right. is this one of those internet jokes im just not getting?
Originally posted by DaNPics would help, I'm not entirely sure what adapter you're talking about. I just used the e30 spider hose and it worked fine. As a general rule, if you are attaching a coolant hose to a nipple or adapter, it will need a hose clamp.
Originally posted by BigD View PostI'm not joking. And I didn't say the cooling system sees no real pressure, I said that juncture doesn't, not until things warm up. It's just the overflow line..
the entire cooling system is pressurized when warm. (everyone knows that, i didnt realize you were talking about when it was cold. my mistake. )
AND parts of the cooling system is under slight hydraulic "thump" pressure upon cold start. its a low pressure thump, but enough to blow a seal that is barely holding on (like a hose with no clamp.)
cheers, jason
I never got to crank it. I was just filling the coolant. Only got a handful in and had a look if anything was seeping and that junction was. The only thing I can think of other than a crack or a tear, is that it was colder than Hilary's cooch in the garage yesterday (my small toes took an hour to get warmed up when I got home, it was like -15 outside) and maybe that plastic fitting shrunk more with the temperature than the rubber... Oh well, I guess I'll try it again with a hose clamp.
Originally posted by BigD View PostI never got to crank it. I was just filling the coolant. Only got a handful in and had a look if anything was seeping and that junction was. The only thing I can think of other than a crack or a tear, is that it was colder than Hilary's cooch in the garage yesterday (my small toes took an hour to get warmed up when I got home, it was like -15 outside) and maybe that plastic fitting shrunk more with the temperature than the rubber... Oh well, I guess I'll try it again with a hose clamp.
so let me get this straight.......
you put a coolant hose on without any clamp, filled the coolant, and are now asking why it leaked?
i think r3v has offically "jumped the shark."
cheers, jason
cheers, jason
For real, D...
Clamp it up, fill it up, and don't worry about it.
Originally posted by matt View Post
For real, D...
you put a coolant hose on without any clamp, filled the coolant, and are now asking why it leaked?Last edited by BigD; 01-20-2008, 11:59 AM.
