So tell me about your cooling fan control setup. I'm going to use an aftermarket electric fan. I made some brackets at work and installed it yesterday. What have you done about the temp sensor? Do you use an OEM part and install it in the side tank? I guess I'm going to buy one of those Painless Wiring controllers. I want to get the one that runs the fan for an extra 30 seconds after shutoff ('cuz I think that's neato).
RealOEM says the thread-pitch for the port on the radiator is 14x1.5. Is that a common size for sensors or will I need to mailorder something?
Thanks
Thanks
