WEIRD IDLE AND clicky clacky lol help please!!!!!!!!
  • nismoman
    • Jul 2006
    • 246
    just seeing if any body's m50 does or did this and if so what could be the cause.
    i have a 94 m50 2.5 vanos.
    and when the engine is cold the motor will start up and idle at like 700 rpm's fairily normal. but after the coolant gauge gets around half way and settles down the engines idle goes up to right around 1k and stays. and then when im driving with the throttle just barely cracked (as if going throguh a parking lot) the motor will act like i dropped the throttle to close and then it will return with a jerk of the car. i dont have my 02 sensor hooked up i have a dinan chip(ive tried swapping dmes with a stock chip in it just to quickly make sure it wasnt the chip) i have a massive cone filter and all the throttle body vents plugged. what the fuck? any body know whats going on or what i could try.
    also i have what sounds like valve train noise. but the sound is more through the headers (i have the tubular headers from fleebay that every body has) i currently have 1k miles on the car since i did the swap. i checked for exhaust leaks and found none. should i just run a quart of atf fluid in there to see if i have a deflated hydraulic lifter ? or is it the headers ringing? any body else with these headers have this problem. they are the obx headers.
    thanks homies!!!!
    1985 s50b30, 91 front and rear valence, e30 m3 suspension, advance design coilovers, GC camber caster plates full solid bushings alla round, adjustable rear arms, ireland sways front and back, ireland big brake kit front and back , team dynamics wheels, 24lb injectore ltw fly, intake , headers, exhaust, so forth so on......
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    I had the same problem but my idle would rev up and down. i had a vacuum leak and also my Idle Control Valve was frozen shut. had to take it off and pry it with a screw drive to losen it, then cleaned it out.
    it may be the headers vibrating off the subframe. how close is it from there?
    • nismoman
      • Jul 2006
      • 246
      The headers arent really close to my control arm bushing or anything because originally the header was hitting the CAB so we cut the flange off and welded it out of the way when i ran my exhaust. the idle valve is a good hunch though because the motor wasnt ran probably for about a year before i had it installed into my car and fired up. i will see if i can get it out of there and screw around with it.
      any other takers on the clicking noise .
      thanks man
      john
