e30 m50 drive shaft
  • 0000000000
    • 473
    e30 m50 drive shaft
    OK, what drive shaft works with a m50nv with a getrag 260 and a s3.73 lsd.
    I have a 325es.
  • e30_kid89
    • Apr 2006
    • 489
    Stock 325i/is driveshaft.
    • 0000000000
      • 473
      sweet. thanks
      • SchnellerVert
        • Sep 2005
        • 3948
        Kind of a no brainer since you haven't swapped any driveline except for the engine correct?
        Sacarstic yes but silly question.
        • 0000000000
          • 473
          yeah, its all done its just that the drive shaft is only partial threded on the slip youk?
          • SchnellerVert
            • Sep 2005
            • 3948
            Did you move the engine and transmission?
            • 0000000000
              • 473
              im not sure, i used e28s motor mounts. the funny looking one.
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Oh lordy.
                • JPStrniste
                  • 146
                  is the e36 non-m tranny a "getrag 250" then?
                  what happens if you had an auto e30 that you swapped in e36 motor and 5spd tranny? then what shoud you use?
                  I got a quote for $220 to modify the stock auto driveshaft with the front half of the e36 driveshaft (so it fits the guibo bolt pattern). Measure, Cut, Cut, weld, spin, balance (entire shaft). Does that sound like a good deal or is there something cheaper...?
                  • etxxz
                    • Feb 2006
                    • 2085
                    e30 = getrag 260 tranny. use stock driveshaft
                    e36 = ZF tranny. use e30 M3, e36 328i or obdII e36 M driveshaft...the ones with 4 bolts in the back.
                    i wouln't cut and weld driveshafts....+ welding weakens worked metal. there's 2 ways of doing things: The right way.
                    No more e30s for me.
                    88 black BMW OBDII 332is dedicated track [sold]
                    88 BMW OBDII bronzit 332is [RIP 03/08]
                    91 BMW 325i [sold]
                    86 Corolla 'Ae86' HB 20v trd [sold]
                    http://youtube.com/watch?v=pTj7Hn9v5Rs
                    • Speedjunkiejp
                      • Jan 2008
                      • 69
                      ok.. how come then i have been told that I have to use the e36 driveshaft even though im using the getrag 240? is it due to rearend?
                      • FredK
                        • 14761
                        Dude. Just get a E36 325i driveshaft for ~$75-120 at ANY junkyard.
                        Not all E36s came with a ZF.
                        E36 325: Getrag 250
                        E36 M3 and 328: ZF 310/320
                        You cannot use a driveshaft meant for a ZF 310/320 on a Getrag 250. The guibos are larger on the ZF trannys. Now it is possible to swap the trans output flange but seriously, don't overthink this. Just get a E36 325i driveshaft.
                        • Speedjunkiejp
                          • Jan 2008
                          • 69
                          bump cause im retarded.. ignore my ignorance..
                          • Mystikal
                            Wheel Fitment Expert
                            • 9602
                            Originally posted by FredK
                            E36 325: Getrag 250
                            Be Carufel, The '95 S50 cars had a Getrag.
                            Jay
                            • PiercedE30
                              • Apr 2005
                              • 4220
                              Also, a bunch of early E34's had ZF310's.
                              My 2.9L Build!
