m50/m52 hybrid
  • ///mza
    • 47
    m50/m52 hybrid
    Hey everyone! I'm looking for some information on the buildup involving an m52 block and a non-vanos m50 head. I've searched everywhere to no avail. Here, e30tech, e3024v, and even bimmerforums (bleh), but I just can't find anything on it. If anyone has any documentation of a swap done like this shoot it my way please, I'm wicked curious to see what kind of numbers these things make and what is needed to run them.
    Do you use the m50's engine management? Which harness, manifold, exhaust, etc. Also, I've read that my 318's getrag 240 bolts up to the m50 and m52, but some people don't recommend it due to the short gearing, would this be cured with a low ratio diff, IE a 3.25 or something along those lines?
    Thanks in advance!
  • smonkbmw
    Professor
    • Jun 2006
    • 4549
    not so much the short gearing. its the capability to handle the power output. a 260 is a lil more stout of a transmission.
    • 02stu
      • Jan 2005
      • 872
      I am running that setup now, non-vanos head and m52 2.8L block. I used the non-vanos head electronics manifolds etc, and just bolted the m52 bottom end on. Wasn't complex at all everything bolted right up. Make sure you plug the oil line that is supposed to run to the vanos unit. I am also using a getrag 240 with a 4.10 rear end, it kinda sucks on the highway but then again I have a two hour commute everyday.
      • AL GReeNeRy
        • 136
        hmmm so all you really need is the engine/ecu parts? driveline and everything else is the same right? what clutch and flywheel are you using?
        1991 318is nv m50 : brilliantrot
        • 02stu
          • Jan 2005
          • 872
          When I said pretty straight forward I meant straight forward compared to a normally m50 swap. You will still need all of the swap bits like the e28 motor mounts, and 320 brake booster, etc. For the drivetrain if you use the 240 you need a e30 325i shift linkage and carrier, an e36 325i driveshaft w/ e30 center bearing, an m20 clutch flywheel and pressure plate, and a m20 starter. As far the ECU goes get the ECU that matches your non-vanos head. In fact use all of the electronics from a non-vanos.
          • alexbaby88
            • 219
            Why not just drop in a crank from the S52/M54 and get the full 3.0L instead of just 2.8L?
            • ///mza
              • 47
              Does the m52 block with the m50 head still make the same 2.8 liter displacement? If I did this swap and was feeling peppy enough someday, would it just be a matter of replacing the head and electronics to gain the function of the vanos?
              to 02stu, do you have a build thread or anything like that of your car?
              And the big question, is an either with an m50/2 swap too much to daily?
              • FredK
                • 14762
                Because dropping in a crank isn't as easy as undoing a few fasteners and tightening them again. There are pistons to shave, pistons rings to file and install, bearings and bearing tolerances to check, etc.
                If you go with a known good M52 2.8L bottom end you can bypass all of this work.
                Why would it be too much to daily? It's not like it's an uncontrollable deathtrap widowmaker, it's an E30 with 210 whp or so.
                • AL GReeNeRy
                  • 136
                  if you had the option of vanos or non-vanos m50 which would you pick? juss wanna swap in the m50 as a budget replacement for my m42 with blown HG. itll stay that way until i can stack money to build it up with proper tranny/driveline and engine work ie, s50/52 internals.
                  • alexbaby88
                    • 219
                    Its the same thing using an M54 bottom end - crank, rods and pistons from M54 AND you get the full 3.0L 84mm bore and 89.6mm stroke, basically an iron blocked M54.
